700r4 Corvette Servo
Discussion in 'The Garage' started by chevydan3, Jul 25, 2005.
  1. chevydan3
    chevydan3 1/2 ton status
    Nov 27, 2004
    409
    Reno, Nevada
  2. chevydan3
    Nov 27, 2004
    409
    Reno, Nevada
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a shift kit is a great idea, a corvette servo is also a great idea, the servo with a longer pin is not such a great idea. by just installing a longer pin, you may do some damage to the tranny. you need to check the movement with the pin you have before you install a different length one.
    there are 3 different length pins, they are identified by the tip. the short one has no rings, 1 ring is the medium length and 2 rings are the longest. you may already have the long pin. the only thing i can think of having a longer pin is to make up for hard part and case tolerances.
    i would just run the pin you have, the only thing is the 1-2 shift would be faster, harder with the correct length pin (which you may have)
  4. chevydan3
    Nov 27, 2004
    409
    Reno, Nevada
    Thanks, my 1-2 shift is pretty stiff and fast on a rebuild 1-1/2 years ago. So I guess I wil just go with the shift kit and the servo w/o pin.
  5. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    if you are gonna do the servo, just get whatever is teh cheapest but has the rings and teflon bands (99% do on ebay from what ive seen, ive only seen 1 that didnt). They are all the same IMO. its a good, cheap mod for the trans. I liked it when i had it in mine, and i need to get another soon.
    One thing i would think about is doing the OD servo while you are in there. OD servos are about $50 tho. thats the only thing stopping me from doing it rt now. I don't wanna go in and replace the 1-2 servo then go in again later and do the OD servo.
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    Also, be aware that a bigger servo = a slower servo. It will change the shift timing slightly. This is a concern on the shift from 2nd to third gear when the servo releases the band and the 3-4 clutch applies. If the band release slows down much, it could cause bind. Some shift kits are designed to be used with the bigger servo. If this is even a problem, it could probably be fixed by enlarging the oil passage into the servo cavity a little bit, but I'm just guessing there.
    The advantage to the 'vette servo is in the 1-2 shift, where you will feel it hit harder. The slight slowdown is irrelevant because application of the band is the only thing happening.
