700r4 crossmember q
Discussion in 'The Garage' started by dheavychevy38, Mar 17, 2006.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Can anyone tell me what the bolt holes are center to center for the crossmember where it bolts to the frame. I forgot to measure it so i could make a solid block instead of just the spacers thanks Denny.
  2. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    i have a crossmember sitting in my garage off an 87 i could measure for you but i am not quite sure what you need? are you just needing straight across from the mounting holes where it bolts to the frame? let me know
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    i need to know from front to back where the spacers go thanks so i can make a solid block so the load is more spread out plus i lost one spacer. :doah:
