700R4 Difference ?s
Discussion in 'The Garage' started by BurbLover, Dec 9, 2003.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    What, if any, are the differences between a 700R4 from behind a 6.2 and one from behind a 350? Can I swap the gas one in for a blown diesel one? Thanks.
  2. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    The transmission is the same but the diesel torque convertor is made to take the torque of the diesel while the torque convertor from the gas truck will work but you run the risk of shelling out the gas torque convertor and ruin your replacement trans. Hope this will help.
    James Startz
  3. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    What if I use the diesel TC from the 6.2 and put it on th replacement tranns?
    Also, my other concern was having the t0case line up properly. Someone tried to tell me the 6.2 had a different bolt up pattern than the 350's or other gas engines. Any truth to that? Thanks.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Nope, to my knowledge there is no difference. I pulled a 6.2 and dropped a TBI 350 right down in the same place and everything bolted up.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you use the old TC from the blown tranny make sure it doesn't have any pieces or chunks, metal flakes, ECT from the old blown tranny in it. That crap will take out the new tranny in a short time. Its always best to use a new TC.
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    There is one MAJOR difference. You'll need to replace the governor in the diesel tranny with one from a gas tranny if you're putting it behind your 350. Diesel tranny governors keep shift points really low. On a gas tranny, under a full-throttle application it shouldn't upshift until you hit about 4500rpm. Diesel probably closer to 3,000rpm...but not sure on that figure.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes just the converter and the governer is different
  8. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I'm putting a gas tranny behind the 6.2. Do I still need to swap? Also, do I need to tear it apart to switch it out, or is it an external thing?
  9. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes other wise you might blow the 6.2. it is a easy swap, on the left side of the tranny, at the rear there is a small cover. that is the governer. pry the cover off and pull the governer out. that easy /forums/images/graemlins/thumb.gif
  10. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    So, to make this idiot er I mean Mark proof:
    1 - pry off both covers
    2 - remove both governors
    3 - switch governors
    4 - replace governors
    5 - replace covers
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    si es mucho correcto
  12. dyeager535
    26,975
    Could be wrong on this, as I haven't dealt with many 700's, but check the cases for the tag that is either riveted on or glued on the side. (my 4L80E has this, as do all 2004R's I've seen, and TH400's as well)
    Anyways, the first of the two large letters is the division (C for Chev, O for Olds, and so on, although not in a logical pattern always) and the second letter is the "strength" rating. A CA would be a weak chev tranny, a CZ would be the beefiest there is.
    Again, not sure if this applies to 700's, but something to consider. Typically the differences are torrington bearings vs. plastic bushings, more or less clutches in some cases, and different valve body/governor calibration.
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    on the 700r4, the 4 cyl and small v6 the internals are different than on a 4.3 v8 and diesel trannys. you can bolt up a 2.8 700r4 to a 350 so no problem /forums/images/graemlins/thumb.gif
