700r4 difference
Discussion in 'The Garage' started by santana, Aug 7, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Is there a difference between a 84 and a 88 700r4?
    Which is a better tranny?
    Will a np208 bolt up where a np241 once went?
    Thanx for your input /forums/images/graemlins/thumb.gif
    Jerry..
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I believe some of the older ones 84 or 85 and older had some problems IIRC other than that I believe they are the same. Yeah I am pretty sure the 208 and 241 are the same.
  3. naranja72
    naranja72 1/2 ton status
    Jan 6, 2002
    110
    vancouver, bc, canada
    the 88-91 years were suppose to have some improvements made to them from chevrolet. I can't remember what was done to it to make it more desirable though.
  4. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Stock to stock, the 88 will be much more durable.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Throughout the years, things changed such as input shaft diameter/spline, auxilary valve bodies, better servo's etc. If you have a choice the newer/later tranny will generally be better/stronger (assuming stock vs. stock). Also if a rebuild is needed, use the newer one. Stay away from the 82 and 83 models (and some early 84's) as they are considered the worst of the worst and some upgrades cannot be performed on them.
