700R4 Electrical Help?
Discussion in 'The Garage' started by PsychoticDeadGuy, Jan 8, 2006.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    What is the 4-prong electrical connection for on my '87 700?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Not 100% but pretty sure that is the torque converter lockup signal from the ECM.
    Ira
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    close, its the lockup wiring, unplug it and lockup won't work and you may overheat the tranny.
  4. PsychoticDeadGuy
    Jan 8, 2005
    753
    so, if i was to put this into a older K5, that had a TH350 in it, it doesnt have the 4-prong thingy, what do i do to make it work?
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    many stand alone kits for under 100 bucks. look in jegs or summit racing. thay sell them. easy to install.
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    what do you mean by stand alone kits? what am i looking for?
  7. sweetk30
    Nov 1, 2004
    25,526
    526
  8. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, thanks alot.
  9. dyeager535
    26,975
    All GM trucks '82-86 with the 700R4 use a standalone wiring harness. Uses engine vacuum and the brake switch to determine lock/unlock. PERSONALLY I wouldn't spend $100 on something that GM already made and is extremely prevalent in the wrecking yards. It's a good system and IMO worked flawlessly.
  10. PsychoticDeadGuy
    Jan 8, 2005
    753
    well, since i am converting my 87 to a manual, i dont need that stuff right? where does it go to up in the engine bay? could i just remove it and would it work with the older truck that has the vacum line that goes direclty to the tranny? would my 87 throw any codes without it?
  11. sandawgk5
    Oct 28, 2003
    6,881
    In 87 the only thing the computer cares about is torque convertor lockup it does not sense anything else on the tranny so swapping in a manual is straight forward. Now 87 and later do not have a standalone tranny computer it is controlled by the vehicles computer so you need to find one from an 86 or earlier with a 700r4.
    Ira
  12. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, so to put my 87 tranny in the older truck, i need to get the lockup stuff off of a 86?
  13. sandawgk5
    Oct 28, 2003
    6,881
    That is correct cause you have to leave the computer in the 87 to run the engine.
    Ira
  14. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, thanks for the help.
