700r4 from a Diesel compatable with a normal 350?
Discussion in 'The Garage' started by bigredblzr, Mar 29, 2004.
  1. bigredblzr
    bigredblzr 1/2 ton status
    May 9, 2003
    151
    NORCAL BABY
    I'm looking at a tranny that is out of a 82 Chevy 1/2ton diesel with a np208 behind it. Would it bolt up to my 91 K5 with gasoline 350 and a np241?
    Thanks,
    Nate
  2. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    The bellhousing will bolt up but you might need a new converter /forums/images/graemlins/k5.gif <font color="blue"> </font>
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it would bolt up but you would need a different torque converter as this is 27 spline and your old is 30. the diesel converter has a lower stall rating. you will have to change the governer also.
    i would stay away from the older 700r4. 82 was the first year and they had way to many problems.
    preaty much any 4x4 700r4 will bolt up, unless someone changed the output shaft to fit a 205 or 203.
  4. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    [/ QUOTE ] Man, you just have all the answer to my stupid tranny questions! Thanks again!
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    its what i do /forums/images/graemlins/deal.gif
  6. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    One more questionfor you then. I swear, it'll be my last one...tonight/forums/images/graemlins/grin.gif. When did the 700r4 turn into the 4L60E?
  7. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    93 was the first year for the 4l60E
  8. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    Thanks man! You're my hero! /forums/images/graemlins/thumb.gif
  9. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    New question. Would a 700r4 off a 4.3L S10 Blazer swap in?
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, as long as its 4x4 its the same. the 2wd have a longer output shaft but same spline
  11. bigredblzr
    May 9, 2003
    151
    NORCAL BABY
    Thanks once again (and prolly not for the last time). /forums/images/graemlins/thumb.gif
  12. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ill be here /forums/images/graemlins/waytogo.gif
