700r4 going out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WakeBoard&4X4er, Aug 16, 2001.
  1. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    i have a question for all you pros out there.
    Just got home from a short (30 min @ 65 ) drive and when i went to pull in to my parking area i heard a "CLUNK". Sounded like the rear end first, but when i went to back in to the parking space i heard it once again and it sounded like the tranny. when i was sitting there i went from R to D to P about 6 time and It kept doing that "Clunk." I was planning to to a Power flush on the tranny some time but is it to late? should i just pull the pan and look for "bad stuff"? or is that "normal" The truck is a 91 k5 with 4 inch lift, tranny cooler, 33s, 700r4 (91 vers know as somthing else), 3.42s, and all other stock 350.
    brett cox
    brettmcox@hotmail.com
  2. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    Sounds like a bad Ujoint maybe??
    '73 K5
    Chevy good...Ford bad
  3. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    is that hard to change klunk?
  4. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Could it be transmission or transfercase mounts? That would be my guess.
    Adam
    79' Jimmy
    3.08's(sucks)
    35's(Bigfoot MT's)
    Np 205, th350, 12B, 10B
    3" suspension lift
  5. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Check your Tcase crossmember bolts. Mine were loose and I was hearing the same CLUNK. If its not that then in might be a Ujoint.
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers... and it's still not BIG ENOUGH!!
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Yeah check the small stuff first... pull out the driveshaft and check the u-jt's... also check to see if the slip yoke (if equiped) is worn and check to see how much play you get in the gears in the rear end... also grab the pry bar and visually inspect the tranny mounts, etc.
    Now one thing that would be bad news is if you are driving and coming to a stop and and then reach a complete stop and a second or more passes and then THUNK! That is bad news... Of course that is only one of the various KLUNKS
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  7. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Ditto on the crossmember bolts - mine was doing the same thing, and I ended up limping home with it barely hanging on. Get a set of 7/16"X2" grade 8 bolts with Nylock nuts and swap them out just for good measure.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  8. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    I hear the same thing. When I put it in park and especially when I put it in drive. My driveshaft and ujoints are pretty much brand new. My transmission was rebuillt last september. I was thinking about going back to the tranny shop and have them look at it being that it is in warranty. It looks like my mounts are fine too. but the CLANK i doin't like....
    Surfing is Life...
  9. 89OKIE
    89OKIE Registered Member
    Aug 16, 2001
    11
    I would like to know what captcrunch knows about the cause for the clunk after you stop. Mine does the same thing, but not all the time. It's in the tranny for sure. It's like it down shifts while your sitting there. Hope you find out.
