700R4 guys, torque converter lockup control?
Discussion in 'The Garage' started by sled_dog, Feb 27, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    What do you guys do about torque converter lockup when using a 700R4 behind a carb motor? Namely my truggy won't have any computer right off the bat. I might install TPI but initially it will be carb and I would rather have my efi standalone and not working my trans. So what do you guys do about torque converter lock up control? A friend of mine had a switch on his dash from an aftermarket control setup someone had installed when the transmission was rebuilt.
  2. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    there's a conversion wiring harness you can buy from Summit
    part # PRF-60109
    http://store.summitracing.com/default.asp?Ntt=700r4&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=0&target=egnsearch.asp&x=13&y=13
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    easy way to do it
    http://www.highperformancecars.com/crosley/lockup1.htm
    easier way is to put a 5/16 check ball under the lockup solenoid. it will lock up in 2nd, 3rd, and 4th. the only problem with that is it wears out the plastic housing after a while, but you can get a metal one for about $20, same cost of a new solenoid.
  4. dyeager535
    26,982
    191
    Just get one off of an "early" 700R4 truck. Already standalone, pretty darn common, and work good.
    I'm not sure that they didn't use that setup until 1991 in "our" body style.
  5. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    you can pickup a kit from bowtie overdrives, thats what I used when I rebuilt my 700r4, automatic lockup in 4th gear and it comes with a little switch for manual lockup in 2nd and 3rd gear, cost me about 75 bucks for the kit and includes everything.
    Heres a link, I put this in mine and its been working great!
    http://www.bowtieoverdrives.com/catalog/catalog_inc/viewitem.php?ITEMID=336
    some fool before me cut out my lockup wiring from the transmission, just snipped the wires off at the TCC and pulled all the wires out! :confused:
    No wonder the transmission didn't have 3rd and 4th gear when I bought the truck.
  6. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    im not to sure how mine is all set up, but i just flip a switch and it will lock up.. i can do it any gear, but just mainly for the hi-way..
    :confused:
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thanks guys. I'm not even sure the trans I am using needs this stuff(it may well be an older one) but its 300 miles away so I can't just go pop in and check. I want to know what I would need if I have the need...
  8. Can Can
    15,555
    152
    Cochrane, Alberta, Canada
    I wish I could be more specific, but when I got my 700r4 rebuilt about ten years ago, I seem to recall the tranny guy mentioning they installed a "cheater" lockup that didn't require any wires. FWIW, mine only locks up in 3rd as far as I can tell.
    Maybe someone could shed some light on this?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have talked to a couple of tranny shops and they say that they perform the lock-up mods internally so you dont need to have the add-on stuff. Never was told the specifics.
    When my buddy changed from TBI to a carb in my 89 p/u he used a B&M kit that you could adjust to the specific mph for the lock-up.. Not a bad kit with a in cab controller, but it is a little pricey.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    most of the time its just the 5/16" check ball
