700R4 Help needed UPDATE problem found
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by doctor4x4, Jan 20, 2004.
  1. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    hey All
    1985 K5 in great shape but
    Any ideas on why it would run so good in 1 &2 and reverse but no 3 -4 ??
    I just bought it from a charity action so no way to know the back ground
    Thanksl
    R
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: 700R4 Help needed Search feature is disabled
    Because the tranny is smoked. Nothing short of a full rebuild cures that symptom. /forums/images/graemlins/frown.gif
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    3-4 clutches are burnt. i was given a tranny by a guy at work and rebuilt it there was nothing left of the 3-4 clutches /forums/images/graemlins/eek.gif
  4. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Whats the fluid look like, Is the tv cable hooke up, does it just not shift out of 2nd?
  5. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    HEy Harry
    and Big 83
    I hope your wrong but am afraid your right
    But as 99firehawk asked - noted it
    just does not shift out of 2nd so ill check tv cable tomorrow morning as the fluid is not to bad a liitle burnt smelling and tinted but nothing like some i have seen
    Thanks guys
    Randy
    Randy
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    does it shift into 2nd at the right time? if it doesn't my money is on the governer valve is stuck. if not it could a vavle in the valve body is stuck. its kinda hard to tell with out driving it what it is.
  7. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    Hey TJ
    Ya seams to shift right time into 2nd so ?? i got it home just fine put it manually in 2nd and just crused it at 40 so here in the next couple days ill pull the pan and see whats up
    Thanks again
    2 all
    R
    But
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Isn't there something along the lines of a "2nd to 3rd accumulator valve" in the R4's? Seems a guy a the local tranny shop mentioned something like this.
    John
  9. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    in another website, it was brought up on how finicky the 700r4's are with the TC cable, this website was posted as being very knowledgable on the 700.
    www.700r4.com
  10. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    you can check over on www.thirdgen.org on the trans board, look for Probuilt automatics, he helps alot of guys over there
    P.S., that is a link to a camaro board
  11. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i had the same problem when i put my shift kit in, pull the valve body out and make sure all of the rods are lubed, if it is dry it won't allow it to shift into gears properly. /forums/images/graemlins/thumb.gif
  12. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    Ya what everyone said, lol, they are all good recommendations. I had the same problem when I first bought my Blazer. First thing I did was get a new cable, around $15, that didn't fix it, but you should get a new one anyways /forums/images/graemlins/smile.gif I had mine rebuilt at a local tranny shop, with a lower in shift kit and T.converter it costed me $1200 with a one year warranty, the warranty helped! one week to the day of the warranty ending it burnt up again /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif got it fixed for free /forums/images/graemlins/smile.gif 2 years now, everything is still perfect down there.
    up here still a little hazy...
  13. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    hey Guys thanks for the links and the extra info thats what I was looking for i plan on playing with it tomorrow
    R
  14. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    When my govener went it would'nt shift out of 1st.
    The plastic gear stripped.
    Here's a pic of it.It was pretty chewed.It happend on my way to BlazerFest last year.
  15. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    well
    Harry and Big 83 win this one
    I pulled the pan today and there was the tell tale sign of all the black clutch material on pan so a little to much to make me happy so pulled the tranny to discover that the last YAhoo
    didnt screw that little bolt in all the way that hold's the TV cable in so inderectly the cable wasnt adjusted right as the cable housing could travel in and out also
    so off to the rebuild shop
    Thansk a million for all the help and ideas guys
    might help some one else down the road when the search feature is working again
    R
  16. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    My 700 shifted fine one day, then wouldnt shift out of first the next. My governor gear looked like that, but none of the teeth were recognizeable. /forums/images/graemlins/eek.gif Just seeing that picture of yours brought back the memory so I just had to post.
    -Harrison
  17. 99firehawk
    Dec 15, 2002
    491
    How much material, You would have to have seriously smoked the clutchs to not allow a shift, I could see if it was sliping but you said it just wouldnt shift. Some material in the pan is normal. I would fix the tv cable change the filter and fill it up and at least give it a shot. Worst case senaro Your out 4$ for the filter and 10$ for some fluid. Best case you save 1000 on a trans.
  18. doctor4x4
    Jan 22, 2002
    1,450
    Los Angeles
    Thanks 99FireHawk
    not to crazy much material nothing like my T400 that i smoked last year but enough to concern me and
    I got a Great hook up on rebuilds 350 - 500 depending on hard parts and hell check it out for free ( 12 pack of beer ) :-) as i allready got it out might as well then im covered for at least a year and the peace of mind knowing it was done right will be priceless to me
    but if i didnt have the great hook up you better believe id be taking your recomendation
    R
