700r4 in drive
Discussion in 'The Garage' started by jacksprat1599, Jan 31, 2005.
  1. jacksprat1599
    jacksprat1599 Registered Member
    Dec 13, 2003
    99
    Austin Tx
    Hey guys I have got some 35s on my truck now and I'm only using it in drive until I get the gears swapped.Is this in anyway bad for my 700 to run this way for a few months.I currently have 3.42 and I'm going to 4.88
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    No, it would be much worse to use OD then to just stay in D. You have the right idea, don't use OD till you get the 4.88's.
    Harley
  3. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    a friend had a old 84 caprice and never used od and got better milage on highway. and it lasted over 160k no problems
  4. jacksprat1599
    Dec 13, 2003
    99
    Austin Tx
    Thanks fellas,I thouhgt it would be okay but I thougt I had read something about no t/c lockup in D and I couldn't rember if that was bad or not.
  5. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    Put another cooler on the trans and a guage if you can get one, a remote filter never hurts either. Keeping the trans cool and clean is the key to a long life.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It should , and will lock up in 3rd , which is good . When I ran the 3.08's and 33's I never shifted to D unless I was flat and at highway speeds . I have thousands of miles on mine , and it will last if you keep the trans in a gear that can carry those tires. I got a cooler on mine within 2 weeks of getting my 33's and lift . The biggest one readily available :k5: :k5:
