700R4 Inspection Cover
Discussion in 'The Garage' started by CHEVY 4WD, Dec 16, 2003.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I have a 700R4 and need a inspection cover The stock only fits if its hacked because I have and like a 153 tooth flexplate, does anyone know where I can get the RIGHT cover for my application I really want a nice Alunimum or even chrome /forums/images/graemlins/eek.gif. Also does a TH350 use the same cover? Ive only found 1 cover forsale in jegs and summit /forums/images/graemlins/confused.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Do you have a K case that uses a cover with 6 bolts rather than a sheet metal cover with 4 screws? TH350/400/700 all use the same cover.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    if i remember correctly his was held on with screws, but i dont think its the right one anyways.. i dont see how hard it could be to MAKE one...
  4. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    mine is held on with 4 1/4-20 bolts, Im not to sure what your talking about as far as a K Case. I know you mount the starter in diffent spots with the differnt flexplate and thats why mine is cut out(the stock one) and I want to get one that fit RIGHT. Think one from a LT1 car would be right?
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If yours is only held on with 4 sheet metal screws then you do not have a K case 4WD tranny. You have just a normal passenger car tranny in your truck. You should be able to find a cover from any late 80's camaro and it should be good since they used the 153 tooth flexplate.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    hmmm... can you explain to me a little more about this "K Case" BTO said I NEED to get the Kcase upgrade on the new trans(Im changing the inspecion cover with the new tranny)I though the K case was just somthing you needed to have on a 4x4
  7. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Basically, the "K" case is a little beffier case. It has an aluminum dust cover rather than the thin steel one and has more material through the bellhousing area. Its a HD case, but I believe the internals are the same.
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    do you know how much more a Kcase tranny weighs then a regular 700R4?
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    4 lbs. (four pounds)
  10. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    wow... thats not bad at all, are the K-cases substantially stronger?
