700r4 - is it OK to drive hwy and town in D?
Discussion in 'The Garage' started by tuner-automotive, May 20, 2005.
  1. tuner-automotive
    tuner-automotive Registered Member
    May 7, 2005
    74
    oregon
    I know this is stupid Q, but it should be Ok to drive around town and HWY in drive instead of OD , correct.?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I usually drive in town in D. But most always use OD on the highway as long as RPMs are 1800 or over. I have no problems and still have the orginal 700R4 in my K5.
  3. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    ditto ;)
  4. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    What size tires and what gearing are you running? I have 33's and 3.73 gears, and I use drive 80% of the time. The only time I use OD is when I'm on flat open highway.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Depends on gearing and useage . I have an 83 so I have no D and OD position , I have simply P-R-N-D-3-2-1 .
    I stayed out of D and used 3 with the 3.08's and 33's . Since my axle swap to ONLY 3.73's , I always use just D ( overdrive ) . I only use 3rd now for towing or really steep grades .
    And wheeling , never use any OD at all .
  6. ryoken
    Jun 13, 2003
    29,621
    1,366
    Jersey Shore
    32's and 3.73's.. i only run OD out on the highway from about 60, 65 and up...
  7. Zeitler
    Zeitler Registered Member
    Feb 22, 2005
    99
    Sweden (Northen Europe)
    is this because the tc only locks at 1800 or above?
    i have 32"s & 2.73's i don't think the tc ever locks ...:crazy: (can't use OD at all)
    but 4.56's is on the way :D
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    I have 3.08's and 33's in my '87 burb. I only use OD if I am on flat, open, long stretches of highway and my speeds are above 75 mph. Anything under that and it sux. I am always in D around town. Even in our buick, we don't use OD unless we are at 60+ mph on the freeways.
  9. jekbrown
    May 19, 2001
    45,029
    361
    Vancouver, WA, USA
    turn your stereo down and listen to the engine... if its racing like mad, put it in OD... otherwise, D is fine.
    j
  10. paveslave
    paveslave Registered Member
    Oct 11, 2003
    36
    Crestview, FL
    The rule I go by is if it can't decide whether it wants to be in 3rd or OD leave it in 3rd.
    Pat :k5:
  11. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Let's put it this way. Never use OD in the city.
  12. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    my truck doesnt shift into OD until after around 40mph. I will keep it in OD for most driving anyways, if its city, it never reaches those higher speeds to even engage OD. If doing local but fast stop and go, I'll keep it out of OD. Otherwise, long stretches of highway, OD it is.
