700R4 is slipping *UPDATED*
Discussion in 'The Garage' started by Tshane, Jan 10, 2004.
  1. Tshane
    Tshane 1/2 ton status
    Nov 26, 2002
    144
    Peoria, Illinois
    My 700R4 has started slipping. Is there anything I can do to it to make it last longer??
    The TV cable worked. I took some slack out of it and the transmission stopped slipping. Thanks to everyone that responded.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: 700R4 is slipping
    Nope, other than don't beat on it.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Fluid and filter change will help, but nothing will keep it alive as long as you'd like it to. Like Tim said, don't beat on it...but there really isn't any hope other than a rebuild/replacement. /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    You can try to put a little more tension on the TV cable so it applies more pressure to the clutch plates. Might bring your shift points up higher but worth a try.
  5. Tshane
    Nov 26, 2002
    144
    Peoria, Illinois
    I had the truck apart for about 6 months and I just put the tranny and motor in. I put a shift kit in the Tranny when i had it apart. Now it is slipping and i never remember it slipping before. Any thing i could of done wrong??
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    you might want to go to www.thirdgen.org and go to tranny board and read up posts, this is a common problem with 700r4 and especially after shift kit installation, which kit did you install ? you will find out alot of info over at thirdgen about all this if you go there.
  7. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    If you did not readjust the T.V. cable after the engine swap this may be where the problem is. Find the procedure for the cable adjustment and give it a shot.
  8. dyeager535
    26,979
    You can always try the additive they make now for auto trans, from what I can make of it, it is a seal conditioner, which means stiff seals would be the only thing it would fix. With a newer trans rebuild anything other than a torn seal is pretty unlikely, but thought I'd toss that option out there.
    I'm a firm believer in that stuff, after accidentally discovering what silicone spray in a leaky hydraulic jack will do.
  9. 88Silverado
    Mar 13, 2003
    2,664
    Really sounds like the TV setup is not adjusted right.
    Read this and check it out.
    TV Cable 101
