700R4 kickdown cable
Discussion in 'The Garage' started by Mr.Doodoo84, Apr 3, 2007.
  1. Mr.Doodoo84
    Mr.Doodoo84 Newbie
    Apr 3, 2007
    Hunterville,NC
    will a 700R4 kickdown cable work with TH350
  2. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,202
    364
    Ridgecrest, CA
    A 700R4 does not have a kickdown cable. It has a Throttle Valve cable which performs a completely different function.
    If you're switching from a 700R4 to a TH350, go to the junkyard and find a kickdown from another TH350.
    If you're going the other way (350 to 700R4) get the correct TV cable and bracketry, read the following article, and do it right. You'll damage the 700R4 if you don't.
    Article: http://www.tciauto.com/Products/Instructions/instructions/gm_tv_cable_adjust.htm
  3. dyeager535
    26,982
    191
    GM may still have a TH350 kickdown cable available, last time I bought a TV cable, it was quite cheap, $12 I think.
    It is better to go with a specific kickdown/TV cable than one of the generic aftermarket "adjustable" ones in any case. Experiences with the aftermarket cables seems to be poor construction, imagine that.
