700R4 Length/Bolt Pattern Question
Discussion in 'The Garage' started by daleearnhardt01, Apr 20, 2004.
  1. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Buddy of mine has a 63 CJ5 with a Buick 3.8 and TH350..He wants to go to a 700R4 for the OD. Im assuming the trans will bolt up to the 3.8 fine right? Is the 700 any longer than a 350? Thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    he will need a 700r4 from a 2.5 or 2.8. the 3.8 uses the same boltpattern as these, NOT the 4.3 and V8. the 700r4 is i think 4" longer than the th350, it might me 3.5".
  3. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    Dunno about the fitment issues w/ the engine & bellhousing but I do know that the 700r4 is 1.75" longer than a th350
    mike
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    It is actually 1 7/8" longer to be exact. /forums/images/graemlins/thumb.gif
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    woops i was way off. /forums/images/graemlins/ignore.gif
    i went to tci's site and their measurements are 1.75 different, 700r4 being longer
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    3.8 is 60 degree, v8 and straight 6 and 305 v6 are 90- degree,
    700r4 is same length as th350 if are both 4x4 and if the th350 is longtail 2wd
    short tail 2wd th350 is 3" shorter than 700r4 just like thm200c and thm2004r and etc,.
    also theres a 12" tail th350 found in mid late 70s wagons,
    th350 longtail 2wd 9" tail is 31 11/16" overall and shorttail 2wd th50 is 3" shorter and 700r4 is same length as the 31 11/16" one
    give or take a 1/16" or so on any of them
  7. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    since when does tailshaft matter on a 4x4? I dont know what all that spew was about, but the fact of the matter is that a 700r4 is 1-3/4" longer than a th350, period. Not 1-7/8. Not 3". Not 3-11/16, Not 12", not 9" etc etc. Dont want to start an arguement over 1/8" (wouldnt be the first time) but Ive personally measured and drilled new holes and its 1.75" exactly
    mike
