700r4 Lockup wiring???
Discussion in 'The Garage' started by BowtieBlazer, Apr 21, 2005.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    This is in a 1985 Blazer, without the computer. I've found lots of posts on the lockup but nothing about wiring. This 700r4 is behind a carbed motor, and has the standard 4 prong plug that plugs into the tranny. On the engine bay side of the harness splits out three plugs, two (black ones) have obvious hook ups, there is a stray red male plug that goes to the passenger side that I can't find the female that it plugs into. Any ideas? Can someone walk outside and check theirs or post up a wiring diagram.
  2. dyeager535
    26,982
    191
    I'd suspect that would be for the vacuum switch, it was/is mounted on the firewall on that side.
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    is it neccesary, or can you jump it out to bypass it?
  4. dyeager535
    26,982
    191
    No reason not to run it.
    I had no complaints with my stock lockup setup in my '83.
    Only three options, short it or leave it open, either it will stay locked up while you try to pass, climb hills, etc., or it will never lock up, always assuming its under a heavy load. Or, get the switch and let it work as intended.
  5. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
