700r4 meet 4l80e
Discussion in 'The Garage' started by neverendingproject, Nov 19, 2006.
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    From this point henceforth, I declare all transmissions problems null and void, and they are now extradited to the nearest junkyard. :D
    :mad: :mad: :mad: :mad: :mad:
    :bow: :bow: :bow: :bow: :bow:
    edit: fixed :mad: :bow: to proper locations.
  2. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    Lol. That F^$king thing on the top is the reason i now have a 3/4 ton burb instead of my 94 blazer. And you think you made a rash decision to eliminate the problem....;)
    Good choice, and i hope we both enjoy long, trouble free service from our 4l80e's......regardless of the vehicle that surround them:bow:
  3. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    if you dont mind me asking how much did you pay for that? my 700 just died and im lookin for another 700 to put into it... but if its not outragious... it would be d@mn nice to put one of those in there.
  4. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    You might barf, but to make a long story short... 450 for controller and 25 for transmission. Yes 25.00
  5. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    So let me get this striaght your pulling out the 4l80 and putting in a 700r4?
  6. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    That insults my intelligence.:shame:
    (I swapped in the 4l80)
  7. dhcomp
    Mar 17, 2001
    9,862
    295
    Truckee, CA
    No, hes putting in the 4l80e
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  9. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    ok makes more sense, have any leads on rebuilt 4l80e I need one for my burb
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its not exactly a direct swap in and go bro. you need computers and crap:doah:
  11. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
  12. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    Yea its not a direct swap thats why I was confused and the 4L80E are not cheap best price I have found is $1200.00 shipped with a 12 month warrenty. Can get one from the dealer for $1950.00 with a 3yr/100,000 mile warrenty
  13. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hope you got the proper t-case output shaft to go with that 4L80E.
  15. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    T-case shifter needs to be lengthed by about an inch, gear selector rod needs to be lengthened by about 2.5 inches, crossmember issues need to be addressed along with cooler lines, bracket for gear selector ("L" shaped bar) needs to be moved back (which I just moved it back one bolt hole), and also make sure your torque converter will bolt up to your flexplate. I also found a sweet spot for the controller. Right between the kick panel and the e-brake bracket. Theres about 2 inches of space all the way up inside and if you take your dash off, you can run the wires up behind the guage cluster.
    Also, the TCI controller is well worth the money. I can tune about anything on that trans.
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    can you get some pics of everything inside and out :) im going to run the stock computer for now, and then eventually probably get the tci controller.
  17. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ill get pics tuesday when I go home.
  18. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I never got mine to die...
    had a friend trying to sit on a console bump it into reverse while I was going 70 plus one day, thought it was a gonner, hell the ride was interesting though:crazy:
    countless n-drops when I was young, pulled a few loads way over what I should have, stomped the gas at just about every light.. never completely killed it, I did take out the tourque converter though:D
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks man i appreciate it.
  20. kgblazerfive
    Dec 2, 2004
    10,621
    610
    Hooper, Utah 84315
    Well my overdrive died in mine and I need another one
