700R4 Not Kicking Down?
Discussion in 'The Garage' started by tjk5, Feb 15, 2004.
  1. tjk5
    tjk5 Newbie
    Feb 15, 2004
    4
    Gillette, WY
    I have a 1991 K5, into which I recently installed a (used but good condition 700-a buddy had it in his truck prior) 700. Everything seems to be working fine, save for the fact that the thing refuses to kick down. Where do I begin to look to take care of this? Kind of a pain on highway trips. Thanks!
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Sounds like a T.V. cable adjustment problem to me. /forums/images/graemlins/thinking.gif
  3. tjk5
    tjk5 Newbie
    Feb 15, 2004
    4
    Gillette, WY
    Does TV adjustment affect kickdown? I have adjusted the TV cable multiple times hoping this would remedy the problem, with the only effect being varying shift points/firmness. /forums/images/graemlins/confused.gif
  4. monsterjim
    monsterjim 1/2 ton status
    Feb 5, 2004
    151
    north Texas
    To adjust it there should be a cable running up to the intake and then onto the throttle linkage. There should be a bracket mounted to the intake with a plastic adjuster running through it. Push in on the square button to release the cable and then move it forward or backward accordingly. Usually the cable sticks out 1/4 of an inch. Its better to be to loose than to tight. To see if you have it adjusted right, start off slowly and as soon as it shifts to 2 on its own, floor it and it should go back to first immedietly.
