700R4/NP203 mating
Discussion in 'OffRoad Design' started by 76SILVERADO, Dec 22, 2003.
  1. 76SILVERADO
    76SILVERADO Registered Member
    Mar 1, 2003
    52
    AZ
    local shop tells me they cant do it... Dont you just use the AA shaft # 50-6900 or the cheap way and use spacer? I currently have th-350 They say nobody sells kit to do it.....From Ck5 garage they said to ask here /forums/images/graemlins/cool.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You are correct, you use the AA shaft and the current adapter you already have. You will have to do some driveshaft mods since the 700R4 is 1 7/8" longer than a TH350. You will also have to move your shifter assembly forward the 1 7/8" so it will come through the floor correctly.
  3. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    Yes you can buy the output shaft or the spacer. But you also have to decide if your going to run lock up. I don't think it is worth doing th swap if you do not. Your tranny will just get hot. Also make sure you run a big tranny cooler. 700r4 do not like heat. Summit & Jegs sells a kit. I had my tranny shop wire it up for me. They also installed my output shaft. My tranny was out of a 87 blazer. You can also have a toggle switch wired up so you can engauge and disengauge lock up. I did not have that done. I also moved my engine forward exactly a 1 3/4. I did not have to mess with my drive lines.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Well, that pretty much covers it.
  5. crawlink5
    crawlink5 1/2 ton status
    Oct 9, 2003
    431
    Spring, TX
    I just got a 700r4 two days ago. About to put it in.
    I like the idea of moving the engine forward. That way if I want to switch back in the future, the driveshafts' cost won't be a waste.
    In what way did you do this? Drill new holes in the crossmenber and move the frame mount forward or make an adapter plate for the engine mounts to the engine? Or just made new solid motor mounts?
    Is it exactly 1 3/4 forward or the actual 1 7/8? I know this is not much difference, but I would rather not figure too much out right now as the weather doesn't seem to want to give me too much time to play right now. I also don't have time to redo.
    Thanks,
    Doug
  6. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    76SILVERADO
    Some additional info clicky
  7. 76SILVERADO
    Mar 1, 2003
    52
    AZ
    thx, im going the shaft route. /forums/images/graemlins/thumb.gif
