700r4+NP205 -- how did you do your front driveshaft?
Discussion in 'The Garage' started by mike reeh, Dec 2, 2003.
  1. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    My front driveshaft on my flanged ('77) NP205 hits the oilpan on my 700.. its the CV that hits, grinding aint gonna help. I dented the oil pan to gain 1/8" of clearance but its ONE EIGHTH of an inch, and I cant clearance anymore because there is something inside the trans protruding down into the pan.. truck is lifted 4 inches or so, and the t-case is dropped 1/2"
    hmmm? /forums/images/graemlins/ears.gif
    mike
  2. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    use the spacer to adapter the 205 instead of the shorter output shaft? thats what I did, no problems with clearance, even with a deep aluminum tranny pan and a big azz HAD shaft... /forums/images/graemlins/laugh.gif
    j
  3. mike reeh
    Jul 23, 2001
    752
    San Diego, CA
    well the AA short shaft is already installed in the already built transmission and the already shortened and lengthened driveshafts are already made /forums/images/graemlins/smile.gif so going with the aluminum is out of the question... I guess if it comes down to it I will have to have a special front shaft made..
    mike
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I guess if it comes down to it I will have to have a special trans pan made..
    mike
    Fixed it for you. I can't see why you'd make a smaller front shaft than the 1330 that you've already got. Have someone fab you a pan with more clearance.
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    mike
    I have the same issue. You can't fab a pan better than the stock one. Thick aluminum pans make it worse. I actually cut my pan and had a tinsman weld in a new piece.
    A previous poster was correct as there is an accumulator right in that corner that only allows you to clearance the pan so much. You can either replace your flange yoke to a different style CV or go with a regular non-CV shaft which is what I am thinking of doing although with the clearanced pan, I have not had an issue.
    My clearance is barely a pinky's worth.....
  6. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I think you should put a 203 in as a spacer
    (Sorry had to do it) /forums/images/graemlins/rotfl.gif
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Nice plug, the 203 makes an excellent spacer but even I didn't think of it this time!
    you could go to the old style 1310 CV that mounts up yoke style instead of plate style. I broke plenty of front 10 bolt parts with that CV so it's a fairly strong setup. In fact, Beck's using that driveshaft now in his buggy.
    I lucked into that smaller CV when I had the 700/205, it's just what I had but it did work.
  8. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    I ran this set up but not with a flange it was a c/v set up. It was close to the pan but did not hit on my 85 K-5.
  9. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    WEre to start and were to end /forums/images/graemlins/thinking.gif
    i just went threw this my self
    best - cheepest- easiest solution in my opion
    is upgrade to a 32 spline front output and then run a ujoint mount drive shaft
    I like the statement " you could go to the old style 1310 CV that mounts up yoke style instead of plate style. I broke plenty of front 10 bolt parts with that CV so it's a fairly strong setup. In fact, Beck's using that driveshaft now in his buggy."
    and that way ya dont need a 203 as a spacer
    i am even thinking about flipping - reversing my drive shaft how crazy is that :-)
    as i have done it a few times on the rear before
    and once ya go yoke ya can
    and i have never seen a flange mount yoke for the front axle :-)
