700r4 problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MA87K5, Jun 25, 2005.
  1. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I have a problem with my 700r4. The problem is that it doesn't shift at the correct rpm. It doesn't slip at all though. No matter where I have the kickdown cable adjusted. I took the valve body off and looked at it. Everything seemed fine. I noticed that the valve that connects to the kickdown cable has alot of play. Also the fluid isn't burned. Any help would be great. I kind of don't want to rebuild it if it is an easy fix. Thanks Year of tranny is 1992.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    700r4's dont have a kickdown cable. they have a T.V cable that is very picky about being adjusted correct. you need a pressure guage on the pressure port to get it set up right. The trannys dont last to long with the cable out of adjustment.
  3. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I have the tv cable adjusted correctly b4 and now. But it still won't shift normal. I installed the tranny in 2001. It has around 95k miles on it.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what do you mean by this, play in which way? in/out side/side up/down?
  5. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    inside the valvebody, oops, in/out play.
  6. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Oh well thanks for the help. I'm just going to rebuild it.
  7. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I did the rebuild. Put back in and filled with fluid. Put it in reverse and nothing. Put it into 1 2 and 3 and it goes into gear, but slips. Put it into overdrive and nothing. So I took the pump out, and doing so I found that the aux valvebody was loose. I also remember not putting the second ring into the pump. After fixing those probs, I put the tranny back together, filled with fluid and presto, a fresh new rebuilt 700r4. Very big grin.
  8. dyeager535
    26,976
    Congrats. :)
    How was it to rebuild?
  9. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Glad you got it fixed. I lost my pc at home (hard-drive) so I'm not on AOL IM anymore (they don't allow it at work). I checked with my tranny guy anyways and he was more than you were looking at elsewhere to rebuild :doah:
    Glad it worked out for you. FYI I did find two 2x4 700's if you know anyone looking, but was unable to locate 4x4 700's in the area.
  10. MA87K5
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    The rebuild was very easy. It only took me about 2 hours to rebuild. Not much different from a th350. The hardest part was removing it. The tranny shifts much smoother and it feels like I have more power.
  11. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    the problem here is that its a 700r4.... those things suck! i have one in my daily driver pickup and even though theres nothing wrong with it, i hate that damn thing... the 700r4 is the work of the devil!
  12. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    i find it very hard to believe that you rebuilt a 700r4 in two hours. but maybe you are a auto tranny tech. replacing all the lip seals and checking the function of the lip seals took me at least 2 hours. i had to buy 4 lip seals for the forward clutch before i got it together and sealed properly. i also put the reverse boost valve in backwards in the pump which left me with a slipping tranny and no reverse. was easier to rebuild the second time.
    ryan
  13. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i agree, ive rebuilt alot of them, and my fastest one was 6 hours. there is ALOT of things to check for clearances and proper movement to make it last.
