700R4 Problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Highlander, Mar 3, 2001.
  1. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I'm not sure what happend today with the trany, on the way back from Boulder the 700r started ticking at idle in gear not in park or neutral, hard shifting and on OD. It has fluid, the ticking sounds like it's coming from the front of the trany it could be the flexplate but i'm not sure. the k5 is an 83 and i don't know how many miles it has on it. the trany and torque converter could very well be rebulit or out of a junk yard. any insite will help greatly thanks Eric I took sometime to listen to the thing while in gear it sounds more like metal grinding and rattleing right now, anyone have a good 700R for sale in colo? buy chance. Eric
    Lost? i'm not lost i'm just disorienated<P ID="edit"><FONT SIZE=-1>Edited by Highlander on 03/03/01 06:34 PM (server time).</FONT></P>
  2. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    I should add that when this thing does shift it feels normal. any thoughts would be helpful. Eric
  3. Ryan
    Ryan Registered Member
    Jan 17, 2001
    27
    Eastern NC
    If it shifts real high or low, it could possibly be a broken or out of whack TV cable. The 700 R in my 83 pickup would make a noise after a fluid change or if it was low on fluid. I wouldn't call it a "tick", but it didn't sound good. I think that came from air in the system which bled out eventually.
  4. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks Ryan, for the replies i'm going to look at the tv cable in the morining, and i just mite change the fluid to. i'm hopeing it's not going to need a new tranny.
  5. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    check your flex plate to torque converter bolts to make sure they are tight. Also look for cracks in the flex plate.
    HTH
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I agree w/ rock.monkey... pull of the scatter shield and then would drop the pan and see if anything is in there. Definetly sounds like loose bolts in the flywheel/torque converter could be a cause. Also droppiong the pan will let you see if there is a lot of clutch, metal or even part of bands in the bottom.
    1987 Chevy K5 Blazer- 350 TBI
  7. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks Rock monkey, Capt. crunch, I'm going to do both today i'll let you guys know what i find out. I damn sure don't need to buy a tranny right now.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Let us know what you find when you open it up. Rotate the flywheel and look up inside with a flashlight so you don't miss anything. It could be as simple as a loose bolt or cracked flexplate. (Let's hope!) Next on the list would be the torque converter or the pump. Either can be replaced without a tranny rebuild, but it's still a lot of work to drop the trans and t-case. [​IMG]
  9. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Well so far i've had the pan off no chunks of bands just alittle metal shavings not a lot. The TV cable is working, I looked at the flexplate no cracks, no loose bolts. So i went to NAPA and got filter and Lucas transmission fix and some ATF. I put all back together and IT STILL DOES IT! I let it warm up ran it down the road 2 miles or so same thing. Anyone got a tranny for sale. or would it be better to go and change the pump or torque converter?
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Are you certain that the noise is coming from the trans itself? Make sure that the noise isn't coming from the engine or an exhaust leak or something like that. Crawl around under the truck while it's idling and see if you can get a good idea of just where the noise originates.
    If it is in the tranny, that could be a bummer. [​IMG] Beware that most tranny shops will want to sell you a total rebuild, regardless of what's actually wrong. [​IMG]
  11. River
    River 1/2 ton status
    May 8, 2000
    121
    Amstelveen, Netherlands
    this is what happened to me. First their was a soft metal sound when the transmission was in neutral and idle. After a view day`s the sound started the become harder. Then i heard it also in drive, and shortly after that the converter blew no drive at all anymore. I had to rebuild the hole transmission and replace the converter.
    My advice listen carefull to find where the sound is coming from if it coms from the converter don`t drive it, replace the converter if you don`t replace it the metal pieces from the broken converter will go into the transmission and then you need a rebuild.
    Hope this will help you to do the right thing.
    Greetings from Amsterdam,
    River `90 K5, 350, TH700R4, NP241, "32, 3.08, 10 bolt F, 10 Bolt R(GOV-Lock)
  12. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks River, When i got under it the sound came from the torque converter area and as i've said it only does it while in gear. I just got a book on it today i'll sit down to tonight and read it, If it is the torque converter would it be worth it to go though the trans to? Was your's hard to shift also? after i did all this today it still does about 30mph at 4000rpm.
  13. dyeager535
    26,980
    Hard to diagnose, but if you are correct in your diagnosis of the area it is coming from, it's likely something in the pump (there are a few valves in there, as well as pump vanes) or maybe the converter. I don't know many people who have had converter problems that didn't include "doesn't move" the torque converter usually takes itself out in fairly short order. My 200R4 (close enough to a 700) had more of what I consider a "buzzing" noise, that got progressively louder. As it got louder, the tranny no longer wanted to upshift. No slipping, but no upshift either. Finally started shifting again, but then the shifts got progressively worse. I parked it, let it sit for a few months, next time I started it, no noise lol. I know its on its way out though, so I am replacing it. All I can say is start saving up. And make sure if you have the 700 "rebuilt" that they use ALL the upgraded parts from the later 700's.
    Dorian
  14. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I'm not sure if this will fix your ticking problem but if i'm reading correctly your trans. doesn't upshift either. When I rebuilt mine, I couldn't get it to upshift until about 4000 RPM. There is a button on your TV cable where it connects to the throttle area. I just pushed that button in and opened the throttle all the way, released the button and it set it to the correct position. Now it shifts perfectly. Don't know if this will help, but if you haven't tried this yet, you might want to before you fork over the cash, it's free.
    85 Blazer on an 82 chassis, 6.2L Diesel, ORD flip, 35's with no cutting on a 4" lift.
  15. Highlander
    Nov 25, 2000
    1,204
    Lakewood Colo
    Thanks for your input dyeager and RLBstine, As of right now it looks like i'll be getting a rebuilt 700R, I've called four places and prices run from 775.00 to 850.00 with torque converter, and one or two had a two year warnty. I've thought about a junk yard tranny but I feel better with a hole differnt tranny in there. Any one have a tranny jack? lol Eric
  16. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Not so fast... If you have a cracked flywheel, which I'm quite sure you do, you won't be able to tell just by shining a flash light up from the dust cover. Sometimes the crackes are even hard to find at close inspection w/ the flywheel off. The exact thing happened to me. It started as a light ticking and only under hard ecceleration, then got progressivly worse. I bought a new converter thinking that was the culprit, only to find it was actually the flywheel. That was around a 100 bucks down the drain. Anyway... good luck, and hope ya fix it what ever it turns out to be! -Tommy
  17. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    you should be looking at 1200 to 1600 to rebuild it right new updates and extra clutch in 3/4 pack (2 clutches added to )not the 12 clutch kit to thin new updated sprag gear ,corvette servo etc.
    88k5 silverado w4"lift soon to have <font color=orange>d44 and corp14ff</font color=orange> with 4.56s
  18. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I agree with coopertwpk. The guy who had my Blazer before me payed almost $1800.00 to rebuild the 700r4. I'd like to find out who has them for $750.00. I'd get a spare........LOL
    Become one with nature............Then marinate it...
  19. Blue85b
    Blue85b Registered Member
    Mar 5, 2001
    22
    If the noise only happens in gear, then it is probably not the pump or converter. They are both spinning all the time the engine is running. If it only happens while the vehicle is moving, you may be looking at bad planetary gears, which mean a full and extra expensive rebuild. The other possibility, as others have already mentioned, is that the flywheel is cracked or the bolts are loose and the load on them when you are in gear is what causes it to make the noise.
    The normal ticking/grinding noise from a 700 is from the pump or torque converter, one of which has just puked and is currently sending shreds of metal throughout your tranny to jack up all of the stuff that wasn't already broken. However, you will most likely hear this regardless of whether or not you are in gear.
  20. dyeager535
    26,980
    Yep, good point. Check flexplate. Start easy, work up to the hard/expensive stuff. My car also has a cracked flex plate, so the ticking could be from that. Not sure why its intermittent, but...under load is the time that it normally makes the noise...its ugly. : )
    Dorian
