700r4 problems
Discussion in 'The Garage' started by camokrawler, Mar 18, 2007.
  1. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    ok so my tranny has been doin fine and i parked it for a month and went out to take it for a spin and it now it slipping in every gear, especially if i stomp on it. any ideas? also if i convert to a th350 with the 208 adapter do i have to worry about and kick down linkages/cables or can i just run it like manual where i shift down/up.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Check fluid level and tv cable adjustment.
    That is about it.
  3. GMCJason
    GMCJason 1/2 ton status
    Dec 23, 2004
    242
    Longmont, CO
    Ditto on the fluid level check. If I leave mine sitting it leaks fluid to the t-case so the tranny is low and the 241 t-case is busting at the seems.
