700R4 problems
Discussion in 'The Garage' started by cybrfire, Jan 29, 2004.
  1. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    OK, fluid is OK. red not burnt. Lots of pressure. I got first gear and reverse. Won't shift. Any suggestions on what I can check beyond that? Is it possible a chunk of ice is floating around in there?
    One other question, I have another trans I could put in but its not an overdrive tranny. How much gas mileage is the overdrive really worth. This is my daily driver.
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    most likely the governer gear is stripped. on the driver side near the rear is a cover for the governer. pull the cover and pull the governer out. if the gear is striped it is like 2.50 for a new one.
    there is a few other posibilities but 80% of the timeit is the governer gear /forums/images/graemlins/waytogo.gif
  4. Klink K5
    Klink K5 1/2 ton status
    Aug 3, 2002
    549
    Northwest Iowa
    Could have a sticky 1-2 valve in the valve body. I would get a can of Sea Foam Trans tune and add that to tranny fluid and try manually shifting it from 1st to second see if you cant break it loose. Also try pulling up and dowm on your detent cable. That valve can also stick and cause your problems. It doesn't take a big piece of debri to stick a valve body in a 700r4. Good luck! Did the trans work ok up to this?
