700r4 probs
Discussion in 'The Garage' started by Poker, May 12, 2006.
  1. Poker
    Poker Registered Member
    Mar 23, 2005
    49
    Texas
    just replaced motor trans COMPLETE. can not get the trans to kick down and go into a passing gear. detent is either to far forward or to far back. linkage maybe? anyone have this prob and know how to fix let me know plz.
    350ci
    700r4
    edlbrock carb (some one said it was a 300 trans) sunno if that helps or hurts.
    thank you
    when i drive ir "right" it works fine . its when i get on it or take off realy fast is when it wants to to be sloppy (kinda sounds like it slipps into N then jumps into gear)
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Fluid level good?
    If its a 700, you may need to adjust the TV cable.
  3. Poker
    Mar 23, 2005
    49
    Texas
    well i just got it back today from the friend that did everything he told me what it was doing and on the way home it did. ill check the fluid
    thnx for reply
  4. dyeager535
    26,980
