700R4 question about good/bad years
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nitrodrip350, Mar 20, 2002.
  1. Nitrodrip350
    Nitrodrip350 1/2 ton status
    Jul 22, 2001
    358
    Centennial, CO
    I know that I read about this here but can't seem to find it in the search engine. Just need to know what the good years are to buy and can the older years be built to be just as good if not better then the new model? Or is there something with the housing that makes them weak? The tranny will be sitting behind a 350 with about 350 - 400 ft/lb.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    In 86 they upgraded from a 6 vein pump to I think a 10 vein pump, causing more line pressure. They made other improvements but I cant remember..anyway these are more desirable. Hughes performance sells a rebuild kit with the red alto clutches and kevlar band that is sweet..and be strong enough for your needs. that combined with a good torque converter and you are set. Be prepared to shell out $500-$700 though...
    brent
  3. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    So 86 and up are the good years right?
  4. mnstr_fx
    mnstr_fx Registered Member
    Sep 13, 2001
    78
    IL
    What you really want is the 88' and up 700's. These have the improved pump, auxilary valve body and I think extra clutches in the 3-4 clutch pack. The older ones can also be built up, but will probably cost you more.
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    ya have 2 options here that I can think of. Buy an 88 or newer factory 700R4, or buy a built one (raptor, art carr, jet perf etc etc). Personally I have a raptor, and it works for me. Any of these built ones, if u slap a big cooler on it and maintain it via well timed servicing etc should serve you well for years and years. If you have a good (and cheap) local shop, u could get a used 88+ factory one and have the shop rebuild/beef it up for you. Make sure it wont cost you tooo much before you have them do it though, a jet or raptor is around $1500... so if the cost of your used one + rebuild parts + labor is over that... it seems pretty pointless to rebuild one.
    J
  6. Nitrodrip350
    Jul 22, 2001
    358
    Centennial, CO
    Nice thanks for all the help
    Shane-
