700R4 question
Discussion in 'The Garage' started by flatline, Feb 10, 2005.
  1. flatline
    flatline 1/2 ton status
    Sep 9, 2004
    167
    Cincinnati, Ohio (area)
    I recently purchased a 84' chevrolet silverado 2500 with a 350 engine and 700R4 transmission. The truck is lifted 6" and has 35" tires, being an overdrive transmission will this lift and tire kill this transmission or will it be okay?
    a friend of mine is totally against this setup and says it will end up in the scrap heap if I don't buy another transmission.:(
    Plans for truck is a Daily Driver with limited use offroad, I may tow with it some time but rare. He has got me really thinking I F'd myself on this deal. :frown1:
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    it should be good, id put a big tranny cooler on it if it dosnt already have one
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    depending on how many miles it has on it could last for a long time or blow up on you... I bought my 88 with the same lift and tires with a blown 700 but it had 180,000 on it. I would say run it till it breaks then get a built 700.
    tranny cooler is a real good idea
  4. flatline
    Sep 9, 2004
    167
    I have a 4 row HD radiator with a tranny cooler built in. Do you think this is enough or should I buy another larger unit to run in front of the radiator.
  5. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    Not sure what you mean by 4 row but that sounds like a stock radiator. The radiator tranny coolers will still be about 45 degrees hotter than a seperate cooler.
    Usually when a stock 700 goes with the stock cooling system hooked up (radiator cooler) its because they got too hot.
    If you want to keep it cool enough IMHO you need a seperate cooler... jegs has them for around 45 bucks.
  6. flatline
    Sep 9, 2004
    167
    The guy I bought it from said the trans was just rebuilt 600 miles ago
  7. flatline
    Sep 9, 2004
    167
    Thanks I will check into the seperate unit, it's a good idea to be safe than sorry!
  8. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    did he say if it was "beefed up"?
  9. flatline
    Sep 9, 2004
    167
    no he didn't say anything about beefing it up
  10. flatline
    Sep 9, 2004
    167
    Does anyone know where I can buy the extra lines to run to the tranny cooler?
  11. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    You should be fine with that tranny. If you re-gear the axles to a lower gear ratio, you will end up with more power and make the tranny last even longer. That is a little costly and involved though. If I were you, I would go to www.summittracing.com Check out B&M External Transmission Coolers. Buy the biggest one they have that is not a race unit. I believe its the stacked plate 2800# cooler. It comes with all necessary hardware and lines. It does a much better job at cooling the tranny that the stock radiator one, because the one in the radiator only allows the tranny fluid to get a s cool as the engine oil temp. Its pretty easy to put in and it should be all you need to keep your tranny happy. One piece of advice though. The B&M kit (like all tranny cooler kits) comes with little plastic zip-ties that you push through the radiator to attach the cooler to the truck. DO NOT USE THESE!! Over time, the plastic ties will wear a hole in the core of your radiator. Go to Lowes, or Home Depot, buy some metal, and fab up a simple mounting bracket that doesnt push through the radiator. That should keep you happy. I have the same tranny, and have been wheeling with it for almost 3 years on 37's (with the B&M cooler).
    -Harrison
  12. flatline
    Sep 9, 2004
    167
    bumping for the later day crowd!
    I just want to be certain that this tranny will not be a pile of crap with the 35's on there
    Axles are stock 8lug (14b I guess?)
  13. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    just count the bolts on the diff cover.
  14. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    i have found lots of people out there that say ( just re built tranny) but all thay did was change about 4 quarts fluid and filter. go under and see if tranny has been out in less than 600 miles as he said and if not then how was it remaned ? and pull the dipstick and look and smell fluid. if clear red good if brown red not so good. and if black bad!!! smell test if like new smell o.k. if burnt or make you want to hurl up then tranny bad. get big cooler and cool that thing. until about87 thay were weak and need lots of mods to hold.
    as for rear axle dont just count bolt . also look for rear hubs like frt but 8 bolts and no lockouts . that is full floater unit 14bolt. if no bolts on rear then semi floater. look in tech section for pumkin pics to id them o.k.
  15. flatline
    Sep 9, 2004
    167
    okay with the last statement on the axle it is a 14b FF rear axle, now assuming this is bone stock what gear is in it?
  16. sweetk30
    Nov 1, 2004
    25,552
    547
    most 4.10 use for stock 4x4 some 4.56 use and havent seen but thay talk about 3.73 a lot on here. most likly 4.10. good all around gears.
  17. pwmin
    pwmin Registered Member
    Jan 27, 2005
    5
    Berthoud/Grand Junction
    i wouldnt worry about it especially if you're going to not offroad with it much and if the tranny was just rebuilt. i put a 700 in my 79 (also 35's) and havent had any problems but i havent been offroading much at all lately. mine has a 12 bolt with stock crap 3.73's. the overdrive will be much nicer anyway for daily driving. thats one of the reasons i swapped that in with the engine and tcase from an 88 tbi. all you have to do is buy an after market tranny cooler and some 3/8" trans fluid line and run both the radiator trans cooler and the a/m one.
  18. flatline
    Sep 9, 2004
    167
    how do you run them both at the same time? Sorry I have never dealt with this before.
  19. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    The cooler will come with instructions :waytogo: :waytogo: :waytogo: :waytogo:
  20. flatline
    Sep 9, 2004
    167
    Yeah I ordered the biggest one they had, comes with everything to hook it up, another question is:
    Will I have to add additional fluid to the transmission since there is added capacity now? I would think I would but want to be sure.
