700R4 question
Discussion in 'The Garage' started by dontoe, May 24, 2005.
  1. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    The '86 Blazer the wife crashed has a 700-208 combo in it. I want to install it in my '75 K-5 that now has a 350-208 combo. Other than the wiring stuff from Trans Adapt or another supplier, can you foresee any problems?
    The later model 700R4's are supposedly better, how can you identify a later model 700R4?
  2. dcubb
    dcubb 1/2 ton status
    Jan 18, 2005
    187
    Pickens, SC
    87' and up are the better versions. One way to tell at a glance is to look for the big "rainbow" shaped casting line on the passenger side of the case (over the cooling line ports). Also look at the #'s stamped on the case right above the right rear corner of the pan. The very first digit indicates year, i.e 7=1987 and so on.
