700R4 Question??
Discussion in 'The Garage' started by TEAMROPER, Apr 19, 2007.
  1. TEAMROPER
    TEAMROPER Registered Member
    Aug 8, 2002
    29
    San Diego
    Any ideas why tranny fluid would be coming out of the transfer case?? Bad rear seal on the tranny??? Thanks for any help.
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I think you just answered your own question. At least that would be my guess. That or a bad seal on the front of your transfer case. :D
    Check your t-case fluid. If it's full, and your tranny is low then it will be that seal. :thumb:
    Rick
  3. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    thanks for your help. That is what I was thinking but wanted to throw it out there.
  4. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Where is the fluid coming out?
  5. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The 208/241 t-case uses ATF. If the tranny is low and the t-case is overfull then you have a bad t-case input seal. If the tranny level is good then you just have a bad t-case seal.
  6. TEAMROPER
    Aug 8, 2002
    29
    San Diego
    It is coming out of the tail shaft (yoke) of the transfer case. The transfer case is a 205. Bowtie overdrive in calfornia built the tranny and installed the output shaft to mate to the 205.
