700r4 questions?
Discussion in 'The Garage' started by hidesertwheelin, Feb 27, 2005.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Does anyone runone of those 700r4 pans with the cooling tubes running through it? Does it work? I know it won't help much on the trail but what about on the freeway? Especially when towing? Also for those with factory oil coolers, where to you mount a aftermarket tranny cooler? The damn oil cooler covers almost half of the radiator.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I just took this pic in total darkness, but if you look closely you can see the outline of the auxilliary cooler to the left of the factory oil cooler. Yup, it almost covers up the entire left hand face of the rad, however it hasn't led to any cooling issues, even when I used to tow a TT across the Rockies every weekend.
    Sorry, I can't help you with any feedback on the finned tranny pans. I run a stock 700r4 pan........
  3. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    That's the Derale pan.
    I think as soon as the air tubes got clogged with crap from 'wheeling, you'd be back to square 1. Well maybe 1.5, since the pan is deeper than stock...
    Plus the tubes going through-and-through make for many more potential leak areas.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I agree about getting plugged... one or two trips through a respectable mud hole and those vents probably won't be vents anymore. I'd save my money..
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I haven't run a tubed' pan, but if you checked it every once in a while and cleaned it out with a good spray 'o' water I don't see why it wouldn't work. I have a regular old deep AL pan that I got from PATC. In combination with a big azz cooler, it works for me.
    j
