700R4 Questions
Discussion in 'The Garage' started by Justin Fleming, Dec 17, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    How do you replace the regulator valve and front pump?
    If these items are bad what are the symptoms.....
    Is it worth changing fluid/filter and adding cleaner to see if on of the valves are just stuck?
    Thanks in Advance
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    what's it doing?.........Its alway's good to drop the pan to see how much clutch material or chunks are in there.
  3. Justin Fleming
    Aug 24, 2005
    767
    4
    Oxford MI
    #4
    [​IMG] Posted Today, 10:19 AM in reply to Justin Fleming's post "How to detirmine what tranny you have"
    Justin Fleming [​IMG] vbmenu_register("postmenu_1399238", true);
    Registered User
    I am certian it is part of the 700r4 family, but I guess someone must have swapped it out to the 4l60e.....Are these ones still A pos? What do you think about my symptoms??
    today when I took it out the trans did not seem to want to shift out of 1st gear. I really had to wind it up very high before it would shift. Other wise when I wind it up really high and then let off it still does not shift, but it seems to go into like a stall and when I gen back into the gas it revs then engauges into 1st.....any ideas?
    It does shift out of 1st if I tack it out and then it goes into second....
    seems like something is sticking or something
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    No offense, but first you need to figure out what tranny you have, and then properly diagnose it. just from what you've said so far it sounds like possible out of trans fluid, or your "TV" cable is way out of adjustment, assuming ofcourse that is a 700r.
