700r4 removal?
Discussion in 'The Garage' started by buffcc1, Oct 9, 2006.
  1. buffcc1
    buffcc1 Registered Member
    May 30, 2005
    42
    Wichita Falls Texas
    I am getting ready to remove my 700r4. There are 3 bolts i can see holding the torque converter to the flywheel. Do I need to remove these or dose the converter stay on the flywheel?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Remove the bolts, the converter comes out with the tranny.
  3. buffcc1
    May 30, 2005
    42
    Wichita Falls Texas
    Is there only the three or is there one on top? If so how do i get to that one?
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Rotate the engine around.
  5. buffcc1
    May 30, 2005
    42
    Wichita Falls Texas
    By rotate you mean?? Kinda learning as i go.
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Take a pry bar on the flywheel or a 5/8's socket on the front balancer bolt and rotate the engine until you can reach the bolt.
  7. buffcc1
    May 30, 2005
    42
    Wichita Falls Texas
    Thanks for the help.
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    are you pulling this out of a blazer? if so, it's easiest to remove the transmission tunnel and then put a cherry picker in there to lower it down. this allows you movement in any direction to get it away from the block. also, it makes access to the top bellhousing bolts much easier. it will also help to support the weight of the engine w/ a floor jack and a piece of lumber under the oil pan.
  9. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Are the tunnels removable in all years blazers or just certain ones? When I say removable, I mean by bolts, not by blue tip wrench.
    I'm going to be faced with a tranny removal soon so I figured I'd ask.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i know for sure that it is for the '83 model year, which has the same body style as your 88, so i'd assume it wouldn't be a problem for you. easy way to check, if you don't want to pull your carpet up, would be to just get under your rig and look for the threaded part of a bolt coming through the floor where the tranny hump meets the floor pan.
  11. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    The tunnel in my 89 does not unbolt.
  12. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    My 88 doesn't appear to unbolt either. It does look like it wouldnt be too hard to remove and replace and make it a bolt up item... the floor does look to be two peices but on mine it looks like its glued together...
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    there is a glue-like sealant in addition to the bolts... mine was this nasy red stuff.
  14. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    my 83 truck unbolts, but my 85 K5 does not. just sealant.
