700r4 removal......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by danzoso, May 20, 2003.
  1. danzoso
    danzoso Newbie
    May 20, 2003
    3
    florida
    Hello eveyone! I am about to undertake my first AT removal. The front seal gave out and now I am going to attempt the replacement. Anyone have any tips or suggestions to aid me in the process? About how much does an automatic trans weigh? Your input is greatly appreciated.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    disconnect the battery
    jack the truck up if you don't have enough room under it without jacking it up.
    pull both drive-lines. if you have a slip yoke rear then use a rattle paint can lid and duck-tape it to the rear when you pull the drive-line that will keep the fluid from going everyplace
    disconnect the speedo cable.
    remove starter
    disconnect shifters
    disconnect kick down cable
    disconnect weiring from tranny
    remove inspection cover that covers the flywheel
    remove the 4 converter bolts
    remove the bottom 4 bell-housing bolts
    put tranny jack under tranny and take the 2 tranny mount bolts out
    take the 4 cross-member bolts out
    slightly lower tranny then get the top 2 bell-housing bolts
    pull tranny back-wards slightly and start to slowly lower
    if you need bolt sizes let me know /forums/images/graemlins/thumb.gif
    also check out this thread
    http://coloradok5.com/forums/showflat.php?Cat=&Board=garage&Number=753861&page=0&view=collapsed&sb=5&o=&fpart=1
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Nevermind, Mudhog explained things far better than me. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    What's the easiest way to get to the top bolts? I have been trying to figure that one out for awhile now. /forums/images/graemlins/smile.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    with a looooooooooonnnnnngggg extension and a swivel socket
  6. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    you might want to pull your distributor cap and your ground strap off first. I had my brother remove my transmission because i was pressed for time and he didnt do theat and let the motor drop and broke both. Needless to say my brother dont work on my truck no more!!!
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    On older trucks you can just lift the carpet and remove the access panel over the tranny/transfer case. But somewhere along the way GM decided that they should glue that panel to the floor. /forums/images/graemlins/angryfire.gif On those rigs, you'll need to break out the 2-foot extension and wobble joint and spend some time swearing under your truck. /forums/images/graemlins/wink.gif
  8. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would be looking at your motor mounts then because that should not happen /forums/images/graemlins/eek.gif
  9. monte0172
    Sep 16, 2002
    182
    Memphis, TN
    there probably worn out like everything else. this summer its getting a new engine. the 400 thats in it has approx 290,000 miles on it and it needs heads in the worst way!! Trying to find a donor truck for a fuel injection swap out.
  10. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Remove the transfer case and crossmember, let the transmission tail end sag down under the truck, then the top bolt's are real easy to get to.
    I've done this way too many times.. thank god I'm doing away with the 700r4... anyone want a "core" 700r4"? /forums/images/graemlins/thumb.gif
  11. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,092
    492
    Grand Rapids area
    Basically, I stick all of my extensions together and put a U-joint on the back of the socket. It's great to do around sunset with the truck facing east /forums/images/graemlins/thumb.gif. Otherwise, just get a good work light behind you. It's hard to do if you can't see.
  12. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I bought some GearWrench wrenches. They're flat ( no angle) and they fit right in there and ratchet away!
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You guys keep thanking God for those huge hands he gave you. Before I had a body lift I simply reached from the top to take out my bellhousing bolts. Much easier that way.
