700r4 repair
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83ChevK5, Nov 9, 2002.
  1. 83ChevK5
    83ChevK5 Registered Member
    Jun 5, 2002
    18
    Seattle, Wa
    How do i remove the pump cover on a 700r4??
  2. YtseJam
    YtseJam 1/2 ton status
    May 19, 2002
    147
    CT USA
    What do you mean? The front pump assembly?
    The transmission has to be removed with the torque converter removed. You must remove the filter and the TCC solenoid and you can either use a pump puller or large screwdriver on the backside of the pump through the bottom of the case( carefully) that's about it.
  3. JAXSTER
    JAXSTER 1/2 ton status
    Mar 15, 2000
    181
    DFW, TEXAS
    <font color="red"> </font color> Plasma Cutter!
