700r4 shaft
Discussion in 'OffRoad Design' started by raymos, Nov 27, 2006.
  1. raymos
    raymos Who?
    Jul 6, 2006
    479
    8
    NOR CAL
    i want to swap a 700r4 into my truck and i was wondering how much the short shaft is and also how hard is it to install? would i be able to use my 205 that is currently mated to a 465 without any modifications?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    You run into front driveline issue when running a 205 behind a 700R4 with the short shaft. No, your existing 205 will not work as it is either the 10 spline version or the 32 spline version and a 700R4 is a 27 spline.
  3. raymos
    raymos Who?
    Jul 6, 2006
    479
    8
    NOR CAL
    what kind of drive shaft issues?
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    what you will run into is that depending on what yoke you use on the 205 it might hit the trans pan.
