700r4 shift kit adjustments
Discussion in 'The Garage' started by highrider_44s, May 7, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    Does anyone know how to adjust the rpm that a 700r4 will shift at going frome 1 to 2nd. This is for a street application in a ta. (not mine) /forums/images/graemlins/deal.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    adjust the TV cable, when you push the button to adjust it, push it in just a little (away from throttle)
    edit: this will affect all gears though, AFAIK you can't change all just one shift without effecting other shifts. on a 4L60E you can adjust every shift point with a computer.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Adjust the TV cable that is next to the trhottle linkage.
  4. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    That tv cable is't for the down shift adjusment is it? /forums/images/graemlins/thinking.gif maby thats only for the 350/400 but if it does make it shift earlier how does it tell it to shift? /forums/images/graemlins/thinking.gif
    I was looking for when you romp on her off the line and she hits 2nd /forums/images/graemlins/peace.gif right now it shifts to late needs to shift earler /forums/images/graemlins/peace.gif
    I'v always liked the 4 speed you can bang a gear any time you want /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/peace.gif yea yeeeea bang the gear /forums/images/graemlins/woot.gif it's only fun till you blow one up /forums/images/graemlins/woot.gif
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Generally you want the tranny to shift later or higher in the RPM range under hard acceleration.
    The TV cable controls both down shifting and how late it shifts up.
  6. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    how would you adjust it to shift earlier? lengthen or shorten and how sesative is it couple mills= 500rpm or so
    /forums/images/graemlins/bow.gif
  7. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    You need to make it tighter, try and give it 2 clicks and see what happens, sometimes it doesn't take much to get it right.
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    tighter=higher rpm shift points
    looser=lower rpm shift points
    tighter is away from throttle
    looser is closer to throttle
    only go 1 click at a time to get it where you want it. /forums/images/graemlins/waytogo.gif
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Adjusting the TV cable isn't the quite the "proper" way to adjust the shift points and you could screw it up doing it that way if you don't know what you are doing (just like with just about anything else).
    It is the govoner that controls WOT shift points. You need to add weight on the tabs or use softer springs in it. Go to the j/y and pull one to mess with so you can always go back to the stock one if you screw it up. All you need is a screw driver to pry back the hold down clamp from the cover on the back drivers side to get one out/in. I think TransGo makes a kit with different springs to mess with it.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Triaged is totally right. Using the TV cable to adjust shift points can blow your tranny.
    If you want to learn what exactly it is you are screwing with. I suggust you read this. TV system101
