700R4 shift kit ?'s
Discussion in 'The Garage' started by rick88blaze, Mar 21, 2003.
  1. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    700R4 shift kit ?\'s
    I installed a RV/heavy duty shift kit in my tranny last weekend and now my shift point have raised dramatically. It won't shift out of first until it gets just above 15 mph, and second won't shift until about 30 mph. Is this normal or did I possibly do something wrong when I installed it. I followed the directions to the letter. /forums/images/graemlins/confused.gif
  2. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    Re: 700R4 shift kit ?\'s
    Check the adjustment on yer TV cable. You may hace to re-adjust it because of the valve body changes. Just a thought.
  3. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i tried adjusting it back and forth a little but it only moves the shift points by 1-3 mph.
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I would take a look at the TV cable, I know that when I but mine in it did raise the shift point I just used the Heavy Duty I didn't go with the street strip.
    Eric
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sounds normal to me. Putting in a shift kit raises the part throttle shift points but doesn't change the full throttle shift points. You'll get used to it.
  6. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Sounds about like mine. Id say its normal.
  7. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    thanks for the replies. at least now i know that it's a normal change in the shift points. /forums/images/graemlins/thumb.gif
  8. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,082
    486
    Grand Rapids area
    What kind of shift kit is it? The shift points should only change a little bit unless the kit specifies that it changes them, or you also did a "shift point" kit. A general shift kit just firms things up.
