700r4 Shift points...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by santana, Sep 30, 2003.
  1. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Is there a common cause for the shift points to be off?
    Way to adjust? /forums/images/graemlins/ears.gif /forums/images/graemlins/thumb.gif
  2. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Shift points are controlled by TV cable adjustment and governor weights and springs.
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Heres another good link on adjustments
    TV Adjustments etc..
    The TV changes part throttle shift points.
    The governor weights/springs controls the WOT shift points.
  5. santana
    Jan 11, 2003
    1,483
    Mesa Arizona
    Played around with it and it looks like I got it nailed down..
    Shifts smooth and tight at the same time and on time..
    Thanks guys!! /forums/images/graemlins/thumb.gif
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    Mine always seemed too wimpy in it's selection of shift points. A Camaro governor fixed that problem /forums/images/graemlins/thumb.gif
    It is essentially identical to the original, but with no weights attached to the little levers!
