700R4 shifting questions
Discussion in 'The Garage' started by gmule, Mar 5, 2003.
  1. gmule
    gmule 1/2 ton status
    Apr 2, 2002
    196
    Conifer Colorado
    What would make a 700R4 shift hard between 1st and 2nd? It shifts so hard that if you don't let up it will snap your head back to the head rest
    All of the other shifts seem normal. It is an 84 Blazer 5.7 4x4 stock 50,000 miles on rebuilt trans.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Most likely your TV (throttle valve) cable is out of adjustment. Well...maybe....is it shifting from 1 to 2 at high rpms? That would be an indication of TV cable out of adjustment.
    But, there are so many other factors. Has it done this since its rebuild? If so, the many ports and valves inside of the tranny could have been altered to give performance shifts (ie, they may have installed a shift kit). Give us some more info to go by.
  3. gmule
    Apr 2, 2002
    196
    Conifer Colorado
    It shifted fine when the transmission was replaced this started a couple of days ago. It shifts hard at any speed or rpm and it shifts really hard at higer rpms.
  4. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    My '90 K5 did the same thing (up shift to 2nd) The TV cable adjustment made it shift like silk. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  5. gmule
    Apr 2, 2002
    196
    Conifer Colorado
    Anybody know how to adjust it?
  6. Catman
    Feb 4, 2003
    53
    Do a search for "TV cable" /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif. At some point there is a link to a site with pics of how to do it. If that fails, read the shop manual. It's a 30 second procedure.
  7. gmule
    Apr 2, 2002
    196
    Conifer Colorado
    Thanks alot
