700R4 shifts late, no fourth gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazinaire, Jul 3, 2002.
  1. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    I adjusted my TV cable and that fixed my problem... for a while. Now the truck is back to shifting to second around 35 and third at 55 and hasn't shifted to fourth yet (even after 85mph.) When I slow to a stop it won't downshift to first unless I wait about 20 seconds, otherwise it will stay in second gear. The fluid level and color are both fine and this trans is a GM rebuilt, was dealer installed in '99, and has about 60k on it. Could the TV cable be slipping and losing its adjustment causing this? What are some other things that would cause this?
  2. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the cable "latch" on the adjuster could be slipping causing your problem to return. If a re-adjustment cures it again, get a new cable and replace your old one. running it out of adjustment can cause internal problems, don't wait too long.
  3. dyeager535
    26,980
    Since you mention GM replacement, I'd expect it not to have a "universal" TV cable, but these have a habit of loosening themselves up, and even tranny shop workers/owners have told me to only use GM or direct fit cables.
