700r4 spacer
Discussion in 'The Garage' started by muddawg, Mar 9, 2005.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    Does anyone know where i can get the spacer for the 700 to bolt a 205 behind it?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    advanced adapters sells kits to hook your 700-r4 up to a 205.
  3. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    they only sell the short 4x4 shaft, i'm looking for the 1.5" or so spacer that makes up for the longer shaft of the 700
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the short shaft is the better way to go. i have heard of poeple having problems with the spacers striping out threads because the 205 is a heavy transfer case
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive never heard that, but i have heard that if you don't use the spacer, the driveshaft will hit the pan.
    i think i can get the just spacer for you.
  6. Rralphs
    Rralphs Newbie
    Mar 9, 2005
    3
    Nederland Colorado
  7. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    I bought mine from ORD. I have the long output shaft in my 700, had to remove about an 1/8" with a Porta-Band, and it still has about 2" of engagement.
  8. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    the AA shaft sucks. Only way I'd run it is if I was already going to rebuild my transmission and I was definitely going to run a doubler. Last thing I need is my front driveshaft hitting my trans pan. I run the spacer, DEEP aluminum pan and NO problems. The spacer has a footing on it with pre-threaded holes that you can use to mount it to a crossmember. With that, plus the normal t-case crossmember I dont see any problem.
    j
  9. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I disagree. I just did the 700r4 to the NP205. I went with the AA shaft. Now I have absolutely no room to put in a 1350 CV front driveshaft because of the tight clearance between the front output and the transmission pan. Now I have to run a 1310 CV up top and a 1350 mated up down at the D60. I'm not happy at having a 1310 CV driving the D60 up front and am worried that I might explode it someday. I thought I had done my homework but now regret going with the AA shaft and not the spacer. I had my 700r4 built at a shop and I don't want to spend the bucks to re-do it.
  10. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I'd like to get my hands on one because someday I will swap out the short shaft for the longer one and use the spacer. I've had people suggest clocking the NP205 up a bit but then I lose my side mount and I'm not so sure I'd gain that much space.
  11. danjeeps
    danjeeps Newbie
    Jan 3, 2005
    california
    this is what you are looking for
    htp://www.teckpack-fitzall.com/index.htm
    or
    transmissionparts USA.com
    spacer part number 7Q-35A
    Quick swap kit. I think its about $60.
  12. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  13. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I just sold one on Ebay for $40 and I had paid $75 for it! Try a company called Quick Swap. For exact model number search my username in the for sale, I should have pics of it in there still.
