700R4 Still Slipping - Now What - Big Help needed!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Nov 18, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    OK, guys...my R4 is still slipping between 2 & 3 and sometimes between 1 & 2. I have replaced the TV cable and adjusted it through all possible settings. It is now in the best of all the settings. I have had the fluid replaced with the power flush system so there is ALL NEW fluid. The thing works great whenever I have it at full throttle. The shifts are good and there is no slipping. However, now the thing still slips whenever I accellerate at slow to medium throttle. I can often feel it starting to shift and slip so I back off on the throttle and it shifts fine. If I do not back off, the tranny slips for several seconds before the next gear engages. I HATE THIS. The company that makes the RAPTOR sells several kits that supposedly fix a few glitches in the R4. These kits allegedly do not require the removal of the tranny. Has anyone else had this problem???? Has anyone else used these kits???? Any help at this point is WELCOME!!!!!! I got to get this fixed. Again,... my R4 has only about 7,500 miles on it. It is a GM factory Crate rebuild. Thanks for any replies
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    if it's only got 7,500 miles, and you bought it from GM- isn't it covered by warranty? even if you put it in yourself, it should still be covered?
    IF ONLY THE 4 YEAR OLD COULD TURN A WRENCH
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear 12 bolt dana 44 front, TIRED ol 305-
  3. 1986Blazer
    Jun 13, 2001
    511
    1 yr or 12,000 - whichever comes first - it has been in almost 20 months. I do not drive all that much here in Key West....it is an island that is 4 miles by 2 miles. I thought of the warranty also and have already checked. Thanks though...
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    The raptor kicks tail! Great tranny IMO. You can also try a addiative called "Lube Gurd" (spelled that way). We have had awsome luck with it in slipping trannys.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I've never tried it, but some say that using type F tranny fluid in a slipping GM tranny can cure "some" problems. If all else fails, it may be worth a shot, but again I have never done this, so I am NOT speaking from personal experience.
    See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot> click here </a>
  6. 1986Blazer
    Jun 13, 2001
    511
    Back to the top.....
    .....any other ideas guys before I blindly start ordering new servos from Raptor????
  7. dyeager535
    26,979
    You can check with www.dorianyeager.com/index2.html
    Why insist on counting when the ring gear has the tooth counts stamped in?
