700r4 stuck in 2nd
Discussion in 'The Garage' started by ou8mud2, Mar 25, 2005.
  1. ou8mud2
    ou8mud2 Banned
    Nov 2, 2004
    18
    Stow, Oh
    88 K5 will not shift out of 2nd. manually can downshift to first then to second but no 3rd or 4th. fluid is full and clean, kickdown cable appears to be operational. anyone know if the electronic shift solenoid is the culprit. thanks bummin in second for now.:confused:
  2. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    Mine did the same thing and it was due to a misadjusted kickdown cable. Have you messed with the carb or anything like that lately? Mine got messed up bad enough that i had to get a new 2nd band :mad: still not too happy about that. It's a lot cheaper than a complete rebuild though. Good luck.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Mine did the same thing as well,,,,needs to be rebuilt,,,mine does anyways.
