700r4 swap into Blazer question
Discussion in 'The Garage' started by Desert Rat, Sep 1, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    For anybody who has swapped out their TH350 for a 700r4, how much did you have to modify the transfer case lever to get it to work? My understanding is the 700r4 is 3-4" longer than the TH350 moving the TC back a bit. Did you modify the lever? Did you have to extend the hole in the floorboard farther back?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    how you adapted the transfer case will play a big role in how far you have to move the lever did you use the output shaft or did you use a spacer?
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i think your backwards, sounds like he is taking out the th350 and putting in a 700r4.
    the 700r4 is 1.75" longer than a th350. you shouldn't need to move the shifter but lengthen the linkage. it should be within adjustment but if not, get the linkage from a 700r4/np208 or 241.
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Yep, pulling the TH350 and putting in most likely a Bowtie Overdrive unit. Good to hear it isn't that far back. I thought it was 3-4 inches longer.
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    are you using the orignal transfer case if you are you will need a spacer because the output shaft sticks out farther which would make the 700 even longer or you can swap in a short output shaft fron advanced adapters which will let you not use a spacer so then it would only be a inch or two longer
  6. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Right now it has an NP205 on it. I called and spoke to BO OD and they told me when I order it (or if I have it built local), that during the rebuild they can put the appropriate short shaft in to match up with the 205.
  7. k5kev
    k5kev Registered Member
    Dec 25, 2002
    57
    Anaheim, CA
    Had a 700r4 put into my '72 w/ a 205. If you use the short tailshaft it'll be 1-3/4' or 1-7/8" longer (can't remember, I wanna say 1-7/8"). I didnt cut the floor, my tranny guy took a /forums/images/graemlins/weld.giftorch to the shifter and bent it into place. Now the shifter is shorter inside the cab. Good luck. /forums/images/graemlins/thumb.gif I have no regrets. /forums/images/graemlins/cool.gif
