700r4 swap out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rockink5, Dec 1, 2002.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I lost park in my 700r4(pin sticking out of case) /forums/images/graemlins/angryfire.gif, and I am considering swapping in a TH400 instead of buying a redone 700. My question is, the 700 has electronics that go to it and the 400 won't. Will this mess with the computer(it's mi 80's)? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif The Blazer has the computer controlled carb and HEI. Insight would be appreciated. /forums/images/graemlins/thumb.gif
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    The electronics that go to the 700-r4 are 4 wires for the lock up convertor for the overdrive. You should be fine just securing the wires up out of the way... I would cover the end of the plug also to help keep crud out in case of future use.
  3. JoseK5
    JoseK5 Registered Member
    Dec 12, 2001
    62
    Lebanon
    I'm no expert, I did the opposite swap, I would think that you would be ok since the TH400 does not need any computer signal. You just have to check if the open electrical connections aren't gonna affect your computer operation or maybe you'll need terminations...
  4. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I did this very swap on the wife's '90 Suburban (700junk4 to TH400 trans) and there was no problems...not even the driveshafts needed to be modified!! /forums/images/graemlins/thumb.gif
