700r4 swap question
Discussion in 'The Garage' started by oneofthefewbmx, Mar 1, 2006.
  1. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    hey guys...i have a real quick question about swapping the 700r4/205 from a 1991 blazer into my 1986 pickup that had a th400/208. i know im goin to have to do somthing w/ my driveshaft lengths, that is no problem...my question was is there any computer or electronic wiring stuff that im goin to have to mess with becuase the blazer is a 1991? any help would be appreciated. thanks alot guys. -mikkie
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    ummm blazers had a 205 behind a 700 r4 in 91?
    should be 241.
    but at anyrate, you will have to hook up the throttle valve cable from the 700 to the carby, and buy a converter lockup switch from a tranny company (pretty sure b&m, tci, transgo make a kit).
  3. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    what is a converter lock up swithch? also, the guy im getting this from swapped the 205 in, he may have swapped the 700r4 in also, im not sure....thanks for your help
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    normally the torque converter lock up is computer controlled.
    with no puter to control it, you need to install a switch to control lockup.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    91 is an electric speedo also.
  6. oneofthefewbmx
    Oct 6, 2004
    579
    Copperas Cove, TX
    hmmmm....electric speedo...that might be a problem...thanks alot for the help guys
