700R4 Swap questions. (already searched)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Xtremjeepn, Dec 12, 2006.
  1. Xtremjeepn
    Xtremjeepn 1/2 ton status
    Jan 17, 2006
    Saddle Rock, CO
    I have read pages and pages of text here and either can't find my specific answers or the links are old and dead. :doah:
    I have a 1974 3/4 ton longbed. Currently has a 454 with a TH350/203.
    I picked up a 700R4/208 combo from an 85 longbed that had a 350cid motor.
    I really want the deeper first and OD. Had planned on waiting on the swap but there is a guy with cash in hand that wants my TH350/203.
    Here are the questions:
    -Will the torque converter in the 700R4 work fine with my 454? (came from a 350) No idea what the stall speed is.
    -Is there a cheap set up to get the TV working(stock parts) or is it best to run the $80 kit from bowtie overdrives?
    -Is there wiring info somewhere for the lockup TC or is the $109 kit from bowtie overdrive the best set up?
    -How do I hook a speedo to this thing?(I honestly did not look but think it is electric)
    -Anyone made a 203 shifter work on a 208? How?
    -Anything else I need to know before I yank out my perfectly good TH350 and make my truck into a planter?
  2. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    Chicopee, Ma 01020
    I would rebuild the 700r4 with good parts b4 the install behind the 454. What year tranny though?
    On the TV hook-up go to the junkyard and get some brackets from trucks with overdrive in them.
    Not sure on the speedo. Might find an older 208 with a cable speedo at the junkyard still in the truck.
    Most of the hook-up parts you can find at the junkyard. And save some $.
    I didn't know 85 trucks had an electronic speedo.
    I got the parts for my 69 camaro to run the 700r4 and was happy with results. I think I spent a total of $15 for everything. I even had to convert to cable speedo, But I had another tranny that had the cable on it. I know the speedo is in the x-fer case and not the tranny, but same situation.
    The converter should bolt up.
