700r4 swap
Discussion in 'The Garage' started by guz71, Oct 5, 2006.
  1. guz71
    guz71 1/2 ton status
    Sep 17, 2006
    387
    lubbock/houston
    I did a search on this but i still have a question. Right now it has th350 mated to np205. From what i read, it mates up but you need a 2 inch spacer because the shaft is longer on the 700r4. So im guessing that is going to push my transfer case back 2 inches, causing me to need driveshafts? if so, is there a way i can just get a shorter output shaft?thanx in advance
  2. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    Funny you should say that... Advance Adapters makes one.
    For a 27 spline np205
    Your Price $172.50 [​IMG]SKU50-6900
    Others are more.
  3. guz71
    Sep 17, 2006
    387
    lubbock/houston
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you would be better off going with the spacer the short shaft when only using the 205 can cause drivline clearence problems with the tranny pan and the fron shaft
  5. guz71
    Sep 17, 2006
    387
    lubbock/houston
    hmmm i see what you are saying. I have a 6 inch suspension lift, so that would change the angle up, but when flexed out im guessing it could be a problem.
  6. grimjaw
    Jun 19, 2004
    944
    Seymour, TN
    Also, I think you would have to tear down the 700r4 to install the short shaft. A spacer is cheap and easy.
  7. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    i say more the 700r4 is longer(2in i think) then the th350 then add 2" more for the spacer neer 4 total you will need to get some better sizes on the trans
  8. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I did the swap. Whatever you do, don't do the short shaft. What happens is that your NP205 then has the front output way too close to your tranny pan. You can't run anything larger than a 1310 CV up front. Eventually, I went with a doubler setup. Partially for the abilities the doubler provided, but also as a solution to not being able to run a larger CV because of the tranny pan clearance. In fact, I ended up going with a HAD front driveshaft with a 42 degree CV which is monstrous. Check out these threads:
    http://coloradok5.com/forums/showthread.php?t=169446&highlight=700r4
    http://coloradok5.com/forums/showthread.php?t=183822
    http://coloradok5.com/forums/showthread.php?t=177118
  9. guz71
    Sep 17, 2006
    387
    lubbock/houston
    okey doke, im going to run the spacer. How much should i expect to pay for the driveshafts?? Looking at those pictures reminds me. The guy that had the truck before me, swapped in the np205 and kept the on the floor shift indicator for the n241....well it doesnt work, so you have to know what gear you are in. Where can i get a slick looking shifter knobs like that? thanx alot for the help yall.
  10. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
  11. guz71
    Sep 17, 2006
    387
    lubbock/houston
    alrighty thanx, i checked lmc and they didnt have them so ill check the other two later.
  12. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    Guz71 when I did the 700r4 swap in my 73 k5 I used a 700r4 out of a 87 blazer and bought the output shaft from advanced adapters. I also purchased from summit a lock up kit and a tranny cooler. I moved my engine up 1 7/8 if I remeber correctly. This made it easier I had no problems with engine clearence and I did not have to mess with my drive shafts. If you do a search you may find my old post. Here is a link that I used when I did the swap it has some good info.
    http://www.off-road.com/4x4web/project/74blazer/tranny/tranny.html
  13. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Did you use and NP205 or an NP203? That makes a big difference. And, what driveshafts did you use on the front? If you retain the stock 1310 CV, then clearance isn't a big issue with the tranny pan. If you want to do a 1350 CV, then it causes headaches. Here is a pic of an NP205 mated up to a 700r4 on a 76 Blazer with a stock 1310 CV shaft. You can see how close the CV is to the pan. You can imagine how close a 1350 would be.
  14. guz71
    Sep 17, 2006
    387
    lubbock/houston
    There building my 700r4 right now, im going to run the shorter output shaft for now due to cost issues with buying new driveshafts. Im really wanting to run the 1 ton axles now so when i buy new rims and tires i wont have to buy new rims again.....plus the 10 bolts are about grenade on me as well.Its not the best decision, but its what im stuck with for now.
  15. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    It's a pay now or pay later game. Just keep in mind that to swap the longer output shaft back in is going to cost you some serious dough. In fact, I might not have done a doubler had I done the spacer route. The doubler is what solved my issue with tranny pan clearance, but at a very high cost. If you plan on upgrading your front shaft later, you will very much regret doing the short shaft. You shouldn't have to buy new shafts anyway. A local shop should be able to extend your front shaft for relatively cheap.
