700r4 t0 a 205
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bushmaster, Mar 18, 2004.
  1. bushmaster
    bushmaster 1/2 ton status
    Jun 1, 2003
    146
    ct
    will a 205 mate to a 700?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    With the right trans output, transfercase input, adapter and sleeve, it should. I am not sure about the splines on each, good drivetrain shop like ORD should be able to set you up with the pieces you need /forums/images/graemlins/k5.gif
  3. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    yes. I ran this combination for a while.
    You can use a stock GM THM350 to 205 adaptor and cut off the end of the stock 700 output shaft (it is about 1/2 inch too long IIRC). Or, you can buy a shorter shaft and custom adaptor from Advanced Adaptors for several hundred bucks. The output shaft by itself is bout $200.
    The GM adaptor I used was bought new from the dealer in 1993. Not sure if it is still available. I can dig out the GM part number if you need it, but I'd get one from Advanced Adaptors that won't crack.
    The cast iron stock adaptor is a weak link. The over hung weight load of the 205 causes it to crack.
    There might be a newer version of the GM adaptor designed for the round pattern 205. I don't know.
  4. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Why do people feel the need to post the same questions in multiple forums? /forums/images/graemlins/confused.gif
  5. bushmaster
    Jun 1, 2003
    146
    ct
    i did a search went thru 50 pages and couldnt find what i was looking for
