700r4 + Tcase oil amount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Psycho, Jun 11, 2002.
  1. K5Psycho
    K5Psycho Registered Member
    Jan 6, 2002
    55
    FL, USA
    how much oil does a 700r4 take
    and
    how much oil does the tcase need
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    After a rebuild with a new torque converter, a 700 takes 23 pints (just shy of 3 gallons). If you have an extra cooler, even more. After dropping the pan for a "fluid change", it will take 3-4 quarts.
    I don't remember how much a 208 or 241 T-case needs, but all you have to do is drain the old stuff into a jug and see how much it is. Then pour that much new stuff in and top off as needed. It is under a gallon.
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    A 208 takes 5 quarts of ATF.
  4. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
    mine took 6 qt's till it started to dribble back out
